昨天还一切正常,今天就没法导出了。 显示文件写入插件程序发生错误
请在Rhino 6 指令行运行 PluginManager 指令,然后检查下 PDF Export 这个插件是否正常被启动。如果有正常启动,且依然有这样的问题,请在 Rhino 6 指令行执行一下 SystemInfo 指令,然后把弹出内容保存后粘贴上来看看。
PDF Export是开的。
Rhino 6 SR27 2020-6-24 (Rhino 6, 6.27.20176.05001, Git hash:master @ ba2c30de00be5a8b210bc297715204e941911799)
License type: 试用版, 版本2020-06-24
License details: Cloud Zoo. In use by: Jackie Mao ()
Expires on: 2020-10-26
Windows 7 SP1 (Physical RAM: 3.9Gb)
Machine name: PC-MSR
Non-hybrid graphics.
Primary display and OpenGL: Intel® HD Graphics 4000 (Intel) Memory: 2GB, Driver date: 8-16-2018 (M-D-Y). OpenGL Ver: 4.0.0 - Build 10.18.10.5059
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Anisotropic Filtering Mode: Height
Vendor Name: Intel
Render version: 4.0
Shading Language: 4.00 - Build 10.18.10.5059
Driver Date: 8-16-2018
Driver Version: 10.18.10.5059
Z-Buffer depth: 24 bits
Total Video Memory: 1852774 KB
Rhino plugins
D:\Program Files\Rhino 6\Plug-ins\Commands.rhp “Commands” 6.27.20176.5001
D:\Program Files\Rhino 6\Plug-ins\WebBrowser.rhp “WebBrowser”
D:\Program Files\Rhino 6\Plug-ins\rdk.rhp “Renderer Development Kit”
D:\Program Files\Rhino 6\Plug-ins\RhinoScript.rhp “RhinoScript”
D:\Program Files\Rhino 6\Plug-ins\IdleProcessor.rhp “IdleProcessor”
D:\Program Files\Rhino 6\Plug-ins\RhinoRender.rhp “Rhino Render”
D:\Program Files\Rhino 6\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 6.27.20176.5001
D:\Program Files\Rhino 6\Plug-ins\NamedSnapshots.rhp “Snapshots”
D:\Program Files\Rhino 6\Plug-ins\Alerter.rhp “Alerter”
D:\Program Files\Rhino 6\Plug-ins\RhinoCycles.rhp “RhinoCycles” 6.27.20176.5001
D:\Program Files\Rhino 6\Plug-ins\export_PDF.rhp “PDF Export” 6.27.20176.5001
D:\Program Files\Rhino 6\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 6.27.20176.5001
D:\Program Files\Rhino 6\Plug-ins\3dxrhino.rhp “3Dconnexion 3D Mouse”
D:\Program Files\Rhino 6\Plug-ins\Displacement.rhp “Displacement”
Rhino 系统信息.txt (2.0 KB)
请更新一下你的 Rhino 6 SR27 至最新的 Rhino6 SR29,然后再测试
但是我这显示还有29天啊。。。![]()
好的 谢谢
更新完了,但是还是不行
请执行 PluginManager, 然后检查下 RDK_EtoUI 是否有正确加载
正确加载了。
但是还是没用
请把最新的 SystemInfo 再抓一遍我看看,谢谢
系统信息2.txt (2.0 KB)
可能需要你卸载 Rhino 6,然后重新安装至默认的C盘,然后再测试PDF另存的问题
好的 我现在重新下载
已经恢复正常了,非常感谢 谢谢
