离线安装也一样 电脑显示已安装net framework 4.8
處理中: Rhino_7_20211121144847.log…
请点击截图钟的 安装日志,保持为txt 文件,然后提交上来看看
txt无上传权限
Redist_VC2015:-2147012867
C:\Users\zheng\AppData\Local\Temp\Rhino_7_20211121183308.log
[182C:1304][2021-11-21T18:33:07]i001: Burn v3.11.100.14911, Windows v10.0 (Build 19042: Service Pack 0), path: C:\Users\zheng\AppData\Local\Temp{B50C72AD-30FE-4E42-AA4E-95DFE37CB28A}.cr\rhino_zh-cn_7.12.21313.06341.exe
[182C:1304][2021-11-21T18:33:07]i000: Initializing string variable ‘BundleVersion’ to value ‘7.12.21313.06341’
[182C:1304][2021-11-21T18:33:07]i000: Initializing string variable ‘CUSTOMER_NAME’ to value ‘’
[182C:1304][2021-11-21T18:33:07]i000: Initializing string variable ‘COMPANY_NAME’ to value ‘’
[182C:1304][2021-11-21T18:33:07]i000: Initializing string variable ‘INSTALLDIR’ to value ‘’
[182C:1304][2021-11-21T18:33:07]i000: Initializing string variable ‘LICENSE_METHOD’ to value ‘’
[182C:1304][2021-11-21T18:33:07]i000: Initializing hidden variable ‘LICENSE_KEY’
[182C:1304][2021-11-21T18:33:07]i000: Initializing hidden variable ‘LICENSE_VALIDATION_CODE’
[182C:1304][2021-11-21T18:33:07]i000: Initializing string variable ‘ZOO_SERVER’ to value ‘’
[182C:1304][2021-11-21T18:33:07]i000: Initializing numeric variable ‘DISABLE_INTERNET_ACCESS’ to value ‘0’
[182C:1304][2021-11-21T18:33:07]i000: Initializing numeric variable ‘ENABLE_AUTOMATIC_UPDATES’ to value ‘1’
[182C:1304][2021-11-21T18:33:07]i000: Initializing numeric variable ‘SEND_STATISTICS’ to value ‘1’
[182C:1304][2021-11-21T18:33:07]i000: Initializing string variable ‘RegistryRoot’ to value ‘Software\McNeel\Rhinoceros\7.0\Install’
[182C:1304][2021-11-21T18:33:07]i000: Initializing string variable ‘FolderName’ to value ‘Rhino 7’
[182C:1304][2021-11-21T18:33:07]i000: Initializing string variable ‘IgnoreFolderName’ to value ‘Rhino 7 WIP’
[182C:1304][2021-11-21T18:33:07]i000: Initializing numeric variable ‘INSTALL_EN’ to value ‘0’
[182C:1304][2021-11-21T18:33:07]i000: Initializing numeric variable ‘INSTALL_FR’ to value ‘0’
[182C:1304][2021-11-21T18:33:07]i000: Initializing numeric variable ‘INSTALL_IT’ to value ‘0’
[182C:1304][2021-11-21T18:33:07]i000: Initializing numeric variable ‘INSTALL_DE’ to value ‘0’
[182C:1304][2021-11-21T18:33:07]i000: Initializing numeric variable ‘INSTALL_ES’ to value ‘0’
[182C:1304][2021-11-21T18:33:07]i000: Initializing numeric variable ‘INSTALL_KO’ to value ‘0’
[182C:1304][2021-11-21T18:33:07]i000: Initializing numeric variable ‘INSTALL_JA’ to value ‘0’
[182C:1304][2021-11-21T18:33:07]i000: Initializing numeric variable ‘INSTALL_TW’ to value ‘0’
[182C:1304][2021-11-21T18:33:07]i000: Initializing numeric variable ‘INSTALL_CN’ to value ‘1’
[182C:1304][2021-11-21T18:33:07]i000: Initializing numeric variable ‘INSTALL_PL’ to value ‘0’
[182C:1304][2021-11-21T18:33:07]i000: Initializing numeric variable ‘INSTALL_CS’ to value ‘0’
[182C:1304][2021-11-21T18:33:07]i000: Initializing numeric variable ‘INSTALL_PT’ to value ‘0’
[182C:1304][2021-11-21T18:33:07]i000: Initializing numeric variable ‘INSTALL_RU’ to value ‘0’
[182C:1304][2021-11-21T18:33:08]i009: Command Line: ‘-burn.clean.room=C:\Users\zheng\Desktop\rhino_zh-cn_7.12.21313.06341.exe -burn.filehandle.attached=664 -burn.filehandle.self=660’
[182C:1304][2021-11-21T18:33:08]i000: Setting string variable ‘WixBundleOriginalSource’ to value ‘C:\Users\zheng\Desktop\rhino_zh-cn_7.12.21313.06341.exe’
[182C:1304][2021-11-21T18:33:08]i000: Setting string variable ‘WixBundleOriginalSourceFolder’ to value ‘C:\Users\zheng\Desktop’
[182C:1304][2021-11-21T18:33:08]i000: Setting string variable ‘WixBundleLog’ to value ‘C:\Users\zheng\AppData\Local\Temp\Rhino_7_20211121183308.log’
[182C:1304][2021-11-21T18:33:08]i000: Setting string variable ‘WixBundleName’ to value ‘Rhino 7’
[182C:1304][2021-11-21T18:33:08]i000: Setting string variable ‘WixBundleManufacturer’ to value ‘Robert McNeel & Associates’
[182C:1304][2021-11-21T18:33:08]i100: Detect begin, 20 packages
[182C:14E0][2021-11-21T18:33:08]i000: OnInitializeLayout
[182C:14E0][2021-11-21T18:33:08]i000: PrivateDetect Begin
[182C:14E0][2021-11-21T18:33:08]i000: Failed to open license file: ‘C:\ProgramData\McNeel\Rhinoceros\6.0\License Manager\Licenses\55500d41-3a41-4474-99b3-684032a4f4df.lic’
[182C:14E0][2021-11-21T18:33:08]i000: GetSystemDefaultLangID() returned 2052
[182C:14E0][2021-11-21T18:33:08]i000: GetUserDefaultLangID() returned 2052
[182C:14E0][2021-11-21T18:33:08]i000: GetOsLanguage() returned cn
[182C:14E0][2021-11-21T18:33:08]i000: version_NT64 = 10.0.0.0; service_pack =
[182C:14E0][2021-11-21T18:33:08]i000: Comparing ver_64 (10.0.0.0) to ver_win_81 (6.3.0.0)
[182C:14E0][2021-11-21T18:33:08]i000: ver_64 !< ver_win_81
[182C:14E0][2021-11-21T18:33:08]i000: Showing UI from C:\Users\zheng\AppData\Local\Temp{37BA8B65-962F-4E71-A532-B296D0A82A7A}.ba\cn\welcome.htm
[182C:1304][2021-11-21T18:33:08]i000: Setting version variable ‘WUAUENG_FILEVERSION’ to value ‘10.0.19041.1320’
[182C:1304][2021-11-21T18:33:08]i000: Setting string variable ‘NETFRAMEWORK45’ to value ‘528372’
[182C:1304][2021-11-21T18:33:08]i052: Condition ‘ReadDisableInternetAccess’ evaluates to false.
[182C:1304][2021-11-21T18:33:08]i000: Setting numeric variable ‘VC2010_exists’ to value 1
[182C:1304][2021-11-21T18:33:08]i052: Condition ‘NOT INSTALLDIR’ evaluates to true.
[182C:1304][2021-11-21T18:33:08]i000: Registry key not found. Key = ‘SOFTWARE\McNeel\Rhinoceros\7.0\Install’
[182C:1304][2021-11-21T18:33:08]i000: Unsetting variable ‘INSTALLDIR’
[182C:1304][2021-11-21T18:33:08]i052: Condition ‘NOT COMPANY_NAME’ evaluates to true.
[182C:1304][2021-11-21T18:33:08]i000: Unsetting variable ‘COMPANY_NAME’
[182C:1304][2021-11-21T18:33:08]i000: Setting string variable ‘VC2015_build’ to value ‘29334’
[182C:1304][2021-11-21T18:33:08]i052: Condition ‘NOT ZOO_SERVER’ evaluates to true.
[182C:1304][2021-11-21T18:33:08]i000: Registry key not found. Key = ‘SOFTWARE\McNeel\Rhinoceros\7.0\License Manager’
[182C:1304][2021-11-21T18:33:08]i000: Unsetting variable ‘ZOO_SERVER’
[182C:1304][2021-11-21T18:33:08]i000: Setting numeric variable ‘VC2013_exists’ to value 1
[182C:1304][2021-11-21T18:33:08]i000: Registry key not found. Key = ‘SOFTWARE\McNeel’
[182C:1304][2021-11-21T18:33:08]i000: Setting numeric variable ‘ReadDisableInternetAccess’ to value 0
[182C:1304][2021-11-21T18:33:08]i000: Setting string variable ‘VC2013_version’ to value ‘12.0.30501.0’
[182C:1304][2021-11-21T18:33:08]i052: Condition ‘NOT SEND_STATISTICS’ evaluates to false.
[182C:1304][2021-11-21T18:33:08]i052: Condition ‘NOT CUSTOMER_NAME’ evaluates to true.
[182C:1304][2021-11-21T18:33:08]i000: Unsetting variable ‘CUSTOMER_NAME’
[182C:1304][2021-11-21T18:33:08]i000: Setting numeric variable ‘VC2015_exists’ to value 1
[182C:1304][2021-11-21T18:33:08]i000: Registry key not found. Key = ‘SOFTWARE\McNeel\McNeelUpdate’
[182C:1304][2021-11-21T18:33:08]i000: Setting numeric variable ‘ReadEnableUpdatesKey’ to value 0
[182C:1304][2021-11-21T18:33:08]i000: Setting numeric variable ‘VC2005_exists’ to value 1
[182C:1304][2021-11-21T18:33:08]i000: Setting string variable ‘VC2010_build’ to value ‘167812379’
[182C:1304][2021-11-21T18:33:08]i052: Condition ‘ReadEnableUpdatesKey’ evaluates to false.
[182C:1304][2021-11-21T18:33:08]i000: Setting string variable ‘VC2005_build’ to value ‘134278728’
[182C:14E0][2021-11-21T18:33:08]i000: Checking for updates at URL https://www.rhino3d.com/feeds/installer/?product=rhino&version=7.12.21313.06341&edition=commercial&locale=zh-cn
[182C:1304][2021-11-21T18:33:08]e000: Error 0x80072efd: Failed to send request to URL: https://www.rhino3d.com/feeds/installer/?product=rhino&version=7.12.21313.06341&edition=commercial&locale=zh-cn, trying to process HTTP status code anyway.
[182C:1304][2021-11-21T18:33:08]e000: Error 0x80072efd: Unknown HTTP status code 0, returned from URL: https://www.rhino3d.com/feeds/installer/?product=rhino&version=7.12.21313.06341&edition=commercial&locale=zh-cn
[182C:1304][2021-11-21T18:33:08]e000: Error 0x80072efd: Failed attempt to download update feed from URL: ‘https://www.rhino3d.com/feeds/installer/?product=rhino&version=7.12.21313.06341&edition=commercial&locale=zh-cn’ to: ‘C:\Users\zheng\AppData\Local\Temp\UpdateFeed_20211121183308.xml’
[182C:1304][2021-11-21T18:33:08]e000: Error 0x80072efd: Failed to download update feed.
[182C:1304][2021-11-21T18:33:08]e000: Error 0x80072efd: Failed to detect atom feed update.
[182C:1304][2021-11-21T18:33:08]e000: Error 0x80072efd: Failed to detect update.
[182C:1304][2021-11-21T18:33:08]i199: Detect complete, result: 0x80072efd
[182C:1304][2021-11-21T18:33:08]i052: Condition ‘VC2005_exists=1 AND VC2005_build>=134278728’ evaluates to true.
[182C:1304][2021-11-21T18:33:08]i052: Condition ‘VC2010_exists=1 AND VC2010_build>=167812379’ evaluates to true.
[182C:1304][2021-11-21T18:33:08]i052: Condition ‘VC2013_exists=1 AND VC2013_version>=v12.0.30501.0’ evaluates to true.
[182C:1304][2021-11-21T18:33:08]i052: Condition ‘VC2015_exists=1 AND VC2015_build>=30135’ evaluates to false.
[182C:1304][2021-11-21T18:33:08]i052: Condition ‘NETFRAMEWORK45 >= 528040’ evaluates to true.
[182C:1304][2021-11-21T18:33:08]i103: Detected related package: {21A8E9ED-1B91-42C3-8C0F-ECF0DE3C2C8E}, scope: PerMachine, version: 7.3.21053.23031, language: 0 operation: MajorUpgrade
[182C:1304][2021-11-21T18:33:08]i103: Detected related package: {FD6BB71B-2563-4191-9DC3-1CEB8DC8CD50}, scope: PerMachine, version: 7.3.21053.23031, language: 0 operation: MajorUpgrade
[182C:1304][2021-11-21T18:33:08]i101: Detected package: Redist_VC2005, state: Present, cached: None
[182C:1304][2021-11-21T18:33:08]i101: Detected package: Redist_VC2010, state: Present, cached: None
[182C:1304][2021-11-21T18:33:08]i101: Detected package: Redist_VC2013, state: Present, cached: None
[182C:1304][2021-11-21T18:33:08]i101: Detected package: Redist_VC2015, state: Absent, cached: None
[182C:1304][2021-11-21T18:33:08]i101: Detected package: NetFx48Redist, state: Present, cached: None
[182C:1304][2021-11-21T18:33:08]i101: Detected package: rhino.msi, state: Absent, cached: None
[182C:1304][2021-11-21T18:33:08]i101: Detected package: rhiexec.msi, state: Absent, cached: None
[182C:1304][2021-11-21T18:33:08]i101: Detected package: en_lang_pack, state: Absent, cached: None
[182C:1304][2021-11-21T18:33:08]i101: Detected package: fr_lang_pack, state: Absent, cached: None
[182C:1304][2021-11-21T18:33:08]i101: Detected package: it_lang_pack, state: Absent, cached: None
[182C:1304][2021-11-21T18:33:08]i101: Detected package: de_lang_pack, state: Absent, cached: None
[182C:1304][2021-11-21T18:33:08]i101: Detected package: es_lang_pack, state: Absent, cached: None
[182C:1304][2021-11-21T18:33:08]i101: Detected package: ko_lang_pack, state: Absent, cached: None
[182C:1304][2021-11-21T18:33:08]i101: Detected package: ja_lang_pack, state: Absent, cached: None
[182C:1304][2021-11-21T18:33:08]i101: Detected package: tw_lang_pack, state: Absent, cached: None
[182C:1304][2021-11-21T18:33:08]i101: Detected package: cn_lang_pack, state: Absent, cached: None
[182C:1304][2021-11-21T18:33:08]i101: Detected package: pl_lang_pack, state: Absent, cached: None
[182C:1304][2021-11-21T18:33:08]i101: Detected package: cs_lang_pack, state: Absent, cached: None
[182C:1304][2021-11-21T18:33:08]i101: Detected package: pt_lang_pack, state: Absent, cached: None
[182C:1304][2021-11-21T18:33:08]i101: Detected package: ru_lang_pack, state: Absent, cached: None
[182C:14E0][2021-11-21T18:33:08]i000: windowsUpdateRequired: ver_NT64 = ‘10.0.0.0’
[182C:14E0][2021-11-21T18:33:08]i000: Showing UI from C:\Users\zheng\AppData\Local\Temp{37BA8B65-962F-4E71-A532-B296D0A82A7A}.ba\cn\install.htm
[182C:1304][2021-11-21T18:33:08]i199: Detect complete, result: 0x0
[182C:14E0][2021-11-21T18:33:10]i000: Setting hidden variable ‘LICENSE_KEY’
[182C:14E0][2021-11-21T18:33:10]i000: Setting string variable ‘CUSTOMER_NAME’ to value ‘’
[182C:14E0][2021-11-21T18:33:10]i000: Setting string variable ‘COMPANY_NAME’ to value ‘’
[182C:14E0][2021-11-21T18:33:10]i000: Setting string variable ‘INSTALLDIR’ to value ‘C:\Program Files\Rhino 7’
[182C:14E0][2021-11-21T18:33:10]i000: Setting numeric variable ‘SEND_STATISTICS’ to value 1
[182C:14E0][2021-11-21T18:33:10]i000: Setting numeric variable ‘ENABLE_AUTOMATIC_UPDATES’ to value 1
[182C:14E0][2021-11-21T18:33:10]i000: Setting numeric variable ‘DISABLE_INTERNET_ACCESS’ to value 0
[182C:14E0][2021-11-21T18:33:10]i000: Setting numeric variable ‘INSTALL_EN’ to value 0
[182C:14E0][2021-11-21T18:33:10]i000: Setting numeric variable ‘INSTALL_FR’ to value 0
[182C:14E0][2021-11-21T18:33:10]i000: Setting numeric variable ‘INSTALL_IT’ to value 0
[182C:14E0][2021-11-21T18:33:10]i000: Setting numeric variable ‘INSTALL_DE’ to value 0
[182C:14E0][2021-11-21T18:33:10]i000: Setting numeric variable ‘INSTALL_ES’ to value 0
[182C:14E0][2021-11-21T18:33:10]i000: Setting numeric variable ‘INSTALL_KO’ to value 0
[182C:14E0][2021-11-21T18:33:10]i000: Setting numeric variable ‘INSTALL_JA’ to value 0
[182C:14E0][2021-11-21T18:33:10]i000: Setting numeric variable ‘INSTALL_TW’ to value 0
[182C:14E0][2021-11-21T18:33:10]i000: Setting numeric variable ‘INSTALL_CN’ to value 1
[182C:14E0][2021-11-21T18:33:10]i000: Setting numeric variable ‘INSTALL_PL’ to value 0
[182C:14E0][2021-11-21T18:33:10]i000: Setting numeric variable ‘INSTALL_CS’ to value 0
[182C:14E0][2021-11-21T18:33:10]i000: Setting numeric variable ‘INSTALL_PT’ to value 0
[182C:14E0][2021-11-21T18:33:10]i000: Setting numeric variable ‘INSTALL_RU’ to value 0
[182C:1304][2021-11-21T18:33:10]i200: Plan begin, 20 packages, action: Install
[182C:1304][2021-11-21T18:33:10]w321: Skipping dependency registration on package with no dependency providers: Redist_VC2005
[182C:1304][2021-11-21T18:33:10]w321: Skipping dependency registration on package with no dependency providers: Redist_VC2010
[182C:1304][2021-11-21T18:33:10]w321: Skipping dependency registration on package with no dependency providers: Redist_VC2013
[182C:1304][2021-11-21T18:33:10]w321: Skipping dependency registration on package with no dependency providers: Redist_VC2015
[182C:1304][2021-11-21T18:33:10]i000: Setting string variable ‘WixBundleLog_Redist_VC2015’ to value ‘C:\Users\zheng\AppData\Local\Temp\Rhino_7_20211121183308_000_Redist_VC2015.log’
[182C:1304][2021-11-21T18:33:10]w321: Skipping dependency registration on package with no dependency providers: NetFx48Redist
[182C:1304][2021-11-21T18:33:10]i000: Setting string variable ‘WixBundleRollbackLog_rhino.msi’ to value ‘C:\Users\zheng\AppData\Local\Temp\Rhino_7_20211121183308_001_rhino.msi_rollback.log’
[182C:1304][2021-11-21T18:33:10]i000: Setting string variable ‘WixBundleLog_rhino.msi’ to value ‘C:\Users\zheng\AppData\Local\Temp\Rhino_7_20211121183308_001_rhino.msi.log’
[182C:1304][2021-11-21T18:33:10]i000: Setting string variable ‘WixBundleRollbackLog_rhiexec.msi’ to value ‘C:\Users\zheng\AppData\Local\Temp\Rhino_7_20211121183308_002_rhiexec.msi_rollback.log’
[182C:1304][2021-11-21T18:33:10]i000: Setting string variable ‘WixBundleLog_rhiexec.msi’ to value ‘C:\Users\zheng\AppData\Local\Temp\Rhino_7_20211121183308_002_rhiexec.msi.log’
[182C:1304][2021-11-21T18:33:10]i052: Condition ‘INSTALL_EN=1’ evaluates to false.
[182C:1304][2021-11-21T18:33:10]i052: Condition ‘INSTALL_FR=1’ evaluates to false.
[182C:1304][2021-11-21T18:33:10]i052: Condition ‘INSTALL_IT=1’ evaluates to false.
[182C:1304][2021-11-21T18:33:10]i052: Condition ‘INSTALL_DE=1’ evaluates to false.
[182C:1304][2021-11-21T18:33:10]i052: Condition ‘INSTALL_ES=1’ evaluates to false.
[182C:1304][2021-11-21T18:33:10]i052: Condition ‘INSTALL_KO=1’ evaluates to false.
[182C:1304][2021-11-21T18:33:10]i052: Condition ‘INSTALL_JA=1’ evaluates to false.
[182C:1304][2021-11-21T18:33:10]i052: Condition ‘INSTALL_TW=1’ evaluates to false.
[182C:1304][2021-11-21T18:33:10]i052: Condition ‘INSTALL_CN=1’ evaluates to true.
[182C:1304][2021-11-21T18:33:10]i000: Setting string variable ‘WixBundleRollbackLog_cn_lang_pack’ to value ‘C:\Users\zheng\AppData\Local\Temp\Rhino_7_20211121183308_003_cn_lang_pack_rollback.log’
[182C:1304][2021-11-21T18:33:10]i000: Setting string variable ‘WixBundleLog_cn_lang_pack’ to value ‘C:\Users\zheng\AppData\Local\Temp\Rhino_7_20211121183308_003_cn_lang_pack.log’
[182C:1304][2021-11-21T18:33:10]i052: Condition ‘INSTALL_PL=1’ evaluates to false.
[182C:1304][2021-11-21T18:33:10]i052: Condition ‘INSTALL_CS=1’ evaluates to false.
[182C:1304][2021-11-21T18:33:10]i052: Condition ‘INSTALL_PT=1’ evaluates to false.
[182C:1304][2021-11-21T18:33:10]i052: Condition ‘INSTALL_RU=1’ evaluates to false.
[182C:1304][2021-11-21T18:33:10]i201: Planned package: Redist_VC2005, state: Present, default requested: Present, ba requested: Present, execute: None, rollback: None, cache: No, uncache: No, dependency: None
[182C:1304][2021-11-21T18:33:10]i201: Planned package: Redist_VC2010, state: Present, default requested: Present, ba requested: Present, execute: None, rollback: None, cache: No, uncache: No, dependency: None
[182C:1304][2021-11-21T18:33:10]i201: Planned package: Redist_VC2013, state: Present, default requested: Present, ba requested: Present, execute: None, rollback: None, cache: No, uncache: No, dependency: None
[182C:1304][2021-11-21T18:33:10]i201: Planned package: Redist_VC2015, state: Absent, default requested: Present, ba requested: Present, execute: Install, rollback: None, cache: Yes, uncache: Yes, dependency: None
[182C:1304][2021-11-21T18:33:10]i201: Planned package: NetFx48Redist, state: Present, default requested: Present, ba requested: Present, execute: None, rollback: None, cache: No, uncache: No, dependency: None
[182C:1304][2021-11-21T18:33:10]i201: Planned package: rhino.msi, state: Absent, default requested: Present, ba requested: Present, execute: Install, rollback: Uninstall, cache: Yes, uncache: No, dependency: Register
[182C:1304][2021-11-21T18:33:10]i201: Planned package: rhiexec.msi, state: Absent, default requested: Present, ba requested: Present, execute: Install, rollback: Uninstall, cache: Yes, uncache: No, dependency: Register
[182C:1304][2021-11-21T18:33:10]i201: Planned package: en_lang_pack, state: Absent, default requested: Absent, ba requested: Absent, execute: None, rollback: None, cache: No, uncache: No, dependency: None
[182C:1304][2021-11-21T18:33:10]i201: Planned package: fr_lang_pack, state: Absent, default requested: Absent, ba requested: Absent, execute: None, rollback: None, cache: No, uncache: No, dependency: None
[182C:1304][2021-11-21T18:33:10]i201: Planned package: it_lang_pack, state: Absent, default requested: Absent, ba requested: Absent, execute: None, rollback: None, cache: No, uncache: No, dependency: None
[182C:1304][2021-11-21T18:33:10]i201: Planned package: de_lang_pack, state: Absent, default requested: Absent, ba requested: Absent, execute: None, rollback: None, cache: No, uncache: No, dependency: None
[182C:1304][2021-11-21T18:33:10]i201: Planned package: es_lang_pack, state: Absent, default requested: Absent, ba requested: Absent, execute: None, rollback: None, cache: No, uncache: No, dependency: None
[182C:1304][2021-11-21T18:33:10]i201: Planned package: ko_lang_pack, state: Absent, default requested: Absent, ba requested: Absent, execute: None, rollback: None, cache: No, uncache: No, dependency: None
[182C:1304][2021-11-21T18:33:10]i201: Planned package: ja_lang_pack, state: Absent, default requested: Absent, ba requested: Absent, execute: None, rollback: None, cache: No, uncache: No, dependency: None
[182C:1304][2021-11-21T18:33:10]i201: Planned package: tw_lang_pack, state: Absent, default requested: Absent, ba requested: Absent, execute: None, rollback: None, cache: No, uncache: No, dependency: None
[182C:1304][2021-11-21T18:33:10]i201: Planned package: cn_lang_pack, state: Absent, default requested: Present, ba requested: Present, execute: Install, rollback: Uninstall, cache: Yes, uncache: No, dependency: Register
[182C:1304][2021-11-21T18:33:10]i201: Planned package: pl_lang_pack, state: Absent, default requested: Absent, ba requested: Absent, execute: None, rollback: None, cache: No, uncache: No, dependency: None
[182C:1304][2021-11-21T18:33:10]i201: Planned package: cs_lang_pack, state: Absent, default requested: Absent, ba requested: Absent, execute: None, rollback: None, cache: No, uncache: No, dependency: None
[182C:1304][2021-11-21T18:33:10]i201: Planned package: pt_lang_pack, state: Absent, default requested: Absent, ba requested: Absent, execute: None, rollback: None, cache: No, uncache: No, dependency: None
[182C:1304][2021-11-21T18:33:10]i201: Planned package: ru_lang_pack, state: Absent, default requested: Absent, ba requested: Absent, execute: None, rollback: None, cache: No, uncache: No, dependency: None
[182C:14E0][2021-11-21T18:33:10]i000: GetSystemDefaultLangID() returned 2052
[182C:14E0][2021-11-21T18:33:10]i000: GetUserDefaultLangID() returned 2052
[182C:14E0][2021-11-21T18:33:10]i000: GetOsLanguage() returned cn
[182C:14E0][2021-11-21T18:33:10]i000: version_NT64 = 10.0.0.0; service_pack =
[182C:14E0][2021-11-21T18:33:10]i000: Comparing ver_64 (10.0.0.0) to ver_win_81 (6.3.0.0)
[182C:14E0][2021-11-21T18:33:10]i000: ver_64 !< ver_win_81
[182C:14E0][2021-11-21T18:33:10]i000: Showing UI from C:\Users\zheng\AppData\Local\Temp{37BA8B65-962F-4E71-A532-B296D0A82A7A}.ba\cn\progress.htm
[182C:1304][2021-11-21T18:33:10]i299: Plan complete, result: 0x0
[182C:1304][2021-11-21T18:33:10]i300: Apply begin
[182C:1304][2021-11-21T18:33:10]i010: Launching elevated engine process.
[182C:1304][2021-11-21T18:33:11]i011: Launched elevated engine process.
[182C:1304][2021-11-21T18:33:11]i012: Connected to elevated engine.
[275C:0B40][2021-11-21T18:33:11]i358: Pausing automatic updates.
[275C:0B40][2021-11-21T18:33:11]i359: Paused automatic updates.
[275C:0B40][2021-11-21T18:33:11]i360: Creating a system restore point.
[275C:0B40][2021-11-21T18:33:11]i361: Created a system restore point.
[275C:0B40][2021-11-21T18:33:11]i370: Session begin, registration key: SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall{dde1b822-81af-42ff-957e-b87fad55db3b}, options: 0x7, disable resume: No
[275C:0B40][2021-11-21T18:33:11]i000: Caching bundle from: ‘C:\Users\zheng\AppData\Local\Temp{37BA8B65-962F-4E71-A532-B296D0A82A7A}.be\Bootstrapper.exe’ to: ‘C:\ProgramData\Package Cache{dde1b822-81af-42ff-957e-b87fad55db3b}\Bootstrapper.exe’
[275C:0B40][2021-11-21T18:33:11]i320: Registering bundle dependency provider: {dde1b822-81af-42ff-957e-b87fad55db3b}, version: 7.12.21313.6341
[275C:0B40][2021-11-21T18:33:11]i371: Updating session, registration key: SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall{dde1b822-81af-42ff-957e-b87fad55db3b}, resume: Active, restart initiated: No, disable resume: No
[182C:3E8C][2021-11-21T18:33:11]w343: Prompt for source of package: Redist_VC2015, payload: Redist_VC2015, path: C:\Users\zheng\Desktop\redist\VC2015_redist_x64.exe
[182C:3E8C][2021-11-21T18:33:11]i338: Acquiring package: Redist_VC2015, payload: Redist_VC2015, download from: https://files.mcneel.com/rhino/6/redistributable/vcredist_x64-14.29.30135.0.exe
[182C:3E8C][2021-11-21T18:33:11]e000: Error 0x80072efd: Failed to send request to URL: https://files.mcneel.com/rhino/6/redistributable/vcredist_x64-14.29.30135.0.exe, trying to process HTTP status code anyway.
[182C:3E8C][2021-11-21T18:33:11]e000: Error 0x80072efd: Unknown HTTP status code 0, returned from URL: https://files.mcneel.com/rhino/6/redistributable/vcredist_x64-14.29.30135.0.exe
[182C:3E8C][2021-11-21T18:33:11]e000: Error 0x80072efd: Failed attempt to download URL: ‘https://files.mcneel.com/rhino/6/redistributable/vcredist_x64-14.29.30135.0.exe’ to: ‘C:\Users\zheng\AppData\Local\Temp{37BA8B65-962F-4E71-A532-B296D0A82A7A}\Redist_VC2015’
[182C:3E8C][2021-11-21T18:33:14]i338: Acquiring package: Redist_VC2015, payload: Redist_VC2015, download from: https://files.mcneel.com/rhino/6/redistributable/vcredist_x64-14.29.30135.0.exe
[182C:3E8C][2021-11-21T18:33:14]e000: Error 0x80072efd: Failed to send request to URL: https://files.mcneel.com/rhino/6/redistributable/vcredist_x64-14.29.30135.0.exe, trying to process HTTP status code anyway.
[182C:3E8C][2021-11-21T18:33:14]e000: Error 0x80072efd: Unknown HTTP status code 0, returned from URL: https://files.mcneel.com/rhino/6/redistributable/vcredist_x64-14.29.30135.0.exe
[182C:3E8C][2021-11-21T18:33:14]e000: Error 0x80072efd: Failed attempt to download URL: ‘https://files.mcneel.com/rhino/6/redistributable/vcredist_x64-14.29.30135.0.exe’ to: ‘C:\Users\zheng\AppData\Local\Temp{37BA8B65-962F-4E71-A532-B296D0A82A7A}\Redist_VC2015’
[182C:3E8C][2021-11-21T18:33:14]w343: Prompt for source of package: Redist_VC2015, payload: Redist_VC2015, path: C:\Users\zheng\Desktop\redist\VC2015_redist_x64.exe
[182C:3E8C][2021-11-21T18:33:17]i338: Acquiring package: Redist_VC2015, payload: Redist_VC2015, download from: https://files.mcneel.com/rhino/6/redistributable/vcredist_x64-14.29.30135.0.exe
[182C:3E8C][2021-11-21T18:33:17]e000: Error 0x80072efd: Failed to send request to URL: https://files.mcneel.com/rhino/6/redistributable/vcredist_x64-14.29.30135.0.exe, trying to process HTTP status code anyway.
[182C:3E8C][2021-11-21T18:33:17]e000: Error 0x80072efd: Unknown HTTP status code 0, returned from URL: https://files.mcneel.com/rhino/6/redistributable/vcredist_x64-14.29.30135.0.exe
[182C:3E8C][2021-11-21T18:33:17]e000: Error 0x80072efd: Failed attempt to download URL: ‘https://files.mcneel.com/rhino/6/redistributable/vcredist_x64-14.29.30135.0.exe’ to: ‘C:\Users\zheng\AppData\Local\Temp{37BA8B65-962F-4E71-A532-B296D0A82A7A}\Redist_VC2015’
[182C:3E8C][2021-11-21T18:33:17]w343: Prompt for source of package: Redist_VC2015, payload: Redist_VC2015, path: C:\Users\zheng\Desktop\redist\VC2015_redist_x64.exe
[182C:3E8C][2021-11-21T18:33:20]i338: Acquiring package: Redist_VC2015, payload: Redist_VC2015, download from: https://files.mcneel.com/rhino/6/redistributable/vcredist_x64-14.29.30135.0.exe
[182C:3E8C][2021-11-21T18:33:20]e000: Error 0x80072efd: Failed to send request to URL: https://files.mcneel.com/rhino/6/redistributable/vcredist_x64-14.29.30135.0.exe, trying to process HTTP status code anyway.
[182C:3E8C][2021-11-21T18:33:20]e000: Error 0x80072efd: Unknown HTTP status code 0, returned from URL: https://files.mcneel.com/rhino/6/redistributable/vcredist_x64-14.29.30135.0.exe
[182C:3E8C][2021-11-21T18:33:20]e000: Error 0x80072efd: Failed attempt to download URL: ‘https://files.mcneel.com/rhino/6/redistributable/vcredist_x64-14.29.30135.0.exe’ to: ‘C:\Users\zheng\AppData\Local\Temp{37BA8B65-962F-4E71-A532-B296D0A82A7A}\Redist_VC2015’
[182C:3E8C][2021-11-21T18:33:20]e000: Error 0x80072efd: Failed to acquire payload from: ‘https://files.mcneel.com/rhino/6/redistributable/vcredist_x64-14.29.30135.0.exe’ to working path: ‘C:\Users\zheng\AppData\Local\Temp{37BA8B65-962F-4E71-A532-B296D0A82A7A}\Redist_VC2015’
[182C:3E8C][2021-11-21T18:33:20]e313: Failed to acquire payload: Redist_VC2015 to working path: C:\Users\zheng\AppData\Local\Temp{37BA8B65-962F-4E71-A532-B296D0A82A7A}\Redist_VC2015, error: 0x80072efd.
[182C:1304][2021-11-21T18:33:20]e000: Error 0x80072efd: Failed while caching, aborting execution.
[275C:0B40][2021-11-21T18:33:20]i372: Session end, registration key: SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall{dde1b822-81af-42ff-957e-b87fad55db3b}, resume: None, restart: None, disable resume: No
[275C:0B40][2021-11-21T18:33:20]i330: Removed bundle dependency provider: {dde1b822-81af-42ff-957e-b87fad55db3b}
[275C:0B40][2021-11-21T18:33:20]i352: Removing cached bundle: {dde1b822-81af-42ff-957e-b87fad55db3b}, from path: C:\ProgramData\Package Cache{dde1b822-81af-42ff-957e-b87fad55db3b}\
[275C:0B40][2021-11-21T18:33:20]i371: Updating session, registration key: SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall{dde1b822-81af-42ff-957e-b87fad55db3b}, resume: None, restart initiated: No, disable resume: No
[182C:1304][2021-11-21T18:33:21]i399: Apply complete, result: 0x80072efd, restart: None, ba requested restart: No
[182C:14E0][2021-11-21T18:33:21]i000: >>>>>> DOWNLOAD CACHE FAILURE <<<<<<
[182C:14E0][2021-11-21T18:33:21]i000: GetSystemDefaultLangID() returned 2052
[182C:14E0][2021-11-21T18:33:21]i000: GetUserDefaultLangID() returned 2052
[182C:14E0][2021-11-21T18:33:21]i000: GetOsLanguage() returned cn
[182C:14E0][2021-11-21T18:33:21]i000: version_NT64 = 10.0.0.0; service_pack =
[182C:14E0][2021-11-21T18:33:21]i000: Comparing ver_64 (10.0.0.0) to ver_win_81 (6.3.0.0)
[182C:14E0][2021-11-21T18:33:21]i000: ver_64 !< ver_win_81
[182C:14E0][2021-11-21T18:33:21]i000: Showing UI from C:\Users\zheng\AppData\Local\Temp{37BA8B65-962F-4E71-A532-B296D0A82A7A}.ba\cn\download_failed.htm
