:0
C:\Users\puzzl\AppData\Local\Temp\Rhino_6_20191008174352.log
[4300:4304][2019-10-08T17:43:51]i001: Burn v3.11.0.11802, Windows v10.0 (Build 18362: Service Pack 0), path: C:\Users\puzzl\AppData\Local\Temp{C40CF114-7771-4D6C-B3AE-EA03CEF52F10}.cr\rhino_en-us_6.5.18155.13161.exe
[4300:4304][2019-10-08T17:43:51]i000: Initializing string variable ‘BundleVersion’ to value ‘6.5.18155.13161’
[4300:4304][2019-10-08T17:43:51]i000: Initializing string variable ‘CUSTOMER_NAME’ to value ‘’
[4300:4304][2019-10-08T17:43:51]i000: Initializing string variable ‘COMPANY_NAME’ to value ‘’
[4300:4304][2019-10-08T17:43:51]i000: Initializing string variable ‘INSTALLDIR’ to value ‘’
[4300:4304][2019-10-08T17:43:51]i000: Initializing string variable ‘LICENSE_METHOD’ to value ‘’
[4300:4304][2019-10-08T17:43:51]i000: Initializing hidden variable ‘LICENSE_KEY’
[4300:4304][2019-10-08T17:43:51]i000: Initializing hidden variable ‘LICENSE_VALIDATION_CODE’
[4300:4304][2019-10-08T17:43:51]i000: Initializing string variable ‘ZOO_SERVER’ to value ‘’
[4300:4304][2019-10-08T17:43:51]i000: Initializing numeric variable ‘ENABLE_AUTOMATIC_UPDATES’ to value ‘1’
[4300:4304][2019-10-08T17:43:51]i000: Initializing numeric variable ‘SEND_STATISTICS’ to value ‘1’
[4300:4304][2019-10-08T17:43:51]i000: Initializing string variable ‘RegistryRoot’ to value ‘Software\McNeel\Rhinoceros\6.0\Install’
[4300:4304][2019-10-08T17:43:51]i000: Initializing string variable ‘FolderName’ to value ‘Rhino 6’
[4300:4304][2019-10-08T17:43:51]i000: Initializing string variable ‘IgnoreFolderName’ to value ‘Rhino WIP’
[4300:4304][2019-10-08T17:43:51]i000: Initializing numeric variable ‘INSTALL_EN’ to value ‘1’
[4300:4304][2019-10-08T17:43:51]i000: Initializing numeric variable ‘INSTALL_FR’ to value ‘0’
[4300:4304][2019-10-08T17:43:51]i000: Initializing numeric variable ‘INSTALL_IT’ to value ‘0’
[4300:4304][2019-10-08T17:43:51]i000: Initializing numeric variable ‘INSTALL_DE’ to value ‘0’
[4300:4304][2019-10-08T17:43:51]i000: Initializing numeric variable ‘INSTALL_ES’ to value ‘0’
[4300:4304][2019-10-08T17:43:51]i000: Initializing numeric variable ‘INSTALL_KO’ to value ‘0’
[4300:4304][2019-10-08T17:43:51]i000: Initializing numeric variable ‘INSTALL_JA’ to value ‘0’
[4300:4304][2019-10-08T17:43:51]i000: Initializing numeric variable ‘INSTALL_TW’ to value ‘0’
[4300:4304][2019-10-08T17:43:51]i000: Initializing numeric variable ‘INSTALL_CN’ to value ‘0’
[4300:4304][2019-10-08T17:43:51]i000: Initializing numeric variable ‘INSTALL_PL’ to value ‘0’
[4300:4304][2019-10-08T17:43:51]i000: Initializing numeric variable ‘INSTALL_CS’ to value ‘0’
[4300:4304][2019-10-08T17:43:51]i000: Initializing numeric variable ‘INSTALL_PT’ to value ‘0’
[4300:4304][2019-10-08T17:43:51]i000: Initializing numeric variable ‘INSTALL_RU’ to value ‘0’
[4300:4304][2019-10-08T17:43:51]i009: Command Line: ‘“-burn.clean.room=D:\Rhinoceros 6.5.18155.13161 Win\rhino_en-us_6.5.18155.13161.exe” -burn.filehandle.attached=640 -burn.filehandle.self=636’
[4300:4304][2019-10-08T17:43:51]i000: Setting string variable ‘WixBundleOriginalSource’ to value ‘D:\Rhinoceros 6.5.18155.13161 Win\rhino_en-us_6.5.18155.13161.exe’
[4300:4304][2019-10-08T17:43:51]i000: Setting string variable ‘WixBundleOriginalSourceFolder’ to value 'D:\Rhinoceros 6.5.18155.13161 Win'
[4300:4304][2019-10-08T17:43:52]i000: Setting string variable ‘WixBundleLog’ to value ‘C:\Users\puzzl\AppData\Local\Temp\Rhino_6_20191008174352.log’
[4300:4304][2019-10-08T17:43:52]i000: Setting string variable ‘WixBundleName’ to value ‘Rhino 6’
[4300:4304][2019-10-08T17:43:52]i000: Setting string variable ‘WixBundleManufacturer’ to value ‘Robert McNeel & Associates’
[4300:4304][2019-10-08T17:43:52]i100: Detect begin, 20 packages
[4300:4320][2019-10-08T17:43:52]i000: GetSystemDefaultLangID() returned 2052
[4300:4320][2019-10-08T17:43:52]i000: GetUserDefaultLangID() returned 2052
[4300:4320][2019-10-08T17:43:52]i000: GetOsLanguage() returned cn
[4300:4320][2019-10-08T17:43:52]i000: version_NT64 = 10.0.0.0; service_pack =
[4300:4320][2019-10-08T17:43:52]i000: Comparing ver_64 (10.0.0.0) to ver_win_7 (6.1.0.0)
[4300:4320][2019-10-08T17:43:52]i000: ver_64 !< ver_win_7
[4300:4320][2019-10-08T17:43:52]i000: Showing UI from C:\Users\puzzl\AppData\Local\Temp{FA58093C-A996-4D5A-9A6B-78749523E65F}.ba\cn\welcome.htm
[4300:4304][2019-10-08T17:43:52]i000: Setting version variable ‘WUAUENG_FILEVERSION’ to value ‘10.0.18362.267’
[4300:4304][2019-10-08T17:43:52]i000: Setting string variable ‘NETFRAMEWORK45’ to value ‘528040’
[4300:4304][2019-10-08T17:43:52]i000: Setting numeric variable ‘VC2010_exists’ to value 1
[4300:4304][2019-10-08T17:43:52]i000: Setting string variable ‘VC2015_build’ to value ‘24215’
[4300:4304][2019-10-08T17:43:52]i000: Registry key not found. Key = ‘SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall{050d4fc8-5d48-4b8f-8972-47c82c46020f}’
[4300:4304][2019-10-08T17:43:52]i000: Setting numeric variable ‘VC2013_exists’ to value 0
[4300:4304][2019-10-08T17:43:52]i000: Setting numeric variable ‘VC2015_exists’ to value 1
[4300:4304][2019-10-08T17:43:52]i000: Registry key not found. Key = ‘SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall{ad8a2fa1-06e7-4b0d-927d-6e54b3d31028}’
[4300:4304][2019-10-08T17:43:52]i000: Setting numeric variable ‘VC2005_exists’ to value 0
[4300:4304][2019-10-08T17:43:52]i000: Setting string variable ‘VC2010_build’ to value ‘167812379’
[4300:4320][2019-10-08T17:43:52]i000: Checking for updates at URL http://www.rhino3d.com/feeds/installer/?product=rhino&version=6.5.18155.13161&edition=commercial&locale=en-us
[4300:4304][2019-10-08T17:43:53]e000: Error 0x8007006e: Failed to parse update atom feed: C:\Users\puzzl\AppData\Local\Temp\UpdateFeed_20191008174352.xml.
[4300:4304][2019-10-08T17:43:53]e000: Error 0x8007006e: Failed to detect atom feed update.
[4300:4304][2019-10-08T17:43:53]e000: Error 0x8007006e: Failed to detect update.
[4300:4304][2019-10-08T17:43:53]i199: Detect complete, result: 0x8007006e
[4300:4304][2019-10-08T17:43:53]i100: Detect begin, 20 packages
[4300:4320][2019-10-08T17:43:53]i000: GetSystemDefaultLangID() returned 2052
[4300:4320][2019-10-08T17:43:53]i000: GetUserDefaultLangID() returned 2052
[4300:4320][2019-10-08T17:43:53]i000: GetOsLanguage() returned cn
[4300:4320][2019-10-08T17:43:53]i000: version_NT64 = 10.0.0.0; service_pack =
[4300:4320][2019-10-08T17:43:53]i000: Comparing ver_64 (10.0.0.0) to ver_win_7 (6.1.0.0)
[4300:4320][2019-10-08T17:43:53]i000: ver_64 !< ver_win_7
[4300:4320][2019-10-08T17:43:53]i000: Showing UI from C:\Users\puzzl\AppData\Local\Temp{FA58093C-A996-4D5A-9A6B-78749523E65F}.ba\cn\welcome.htm
[4300:4304][2019-10-08T17:43:53]i000: Setting version variable ‘WUAUENG_FILEVERSION’ to value ‘10.0.18362.267’
[4300:4304][2019-10-08T17:43:53]i000: Setting string variable ‘NETFRAMEWORK45’ to value ‘528040’
[4300:4304][2019-10-08T17:43:53]i000: Setting numeric variable ‘VC2010_exists’ to value 1
[4300:4304][2019-10-08T17:43:53]i000: Setting string variable ‘VC2015_build’ to value ‘24215’
[4300:4304][2019-10-08T17:43:53]i000: Registry key not found. Key = ‘SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall{050d4fc8-5d48-4b8f-8972-47c82c46020f}’
[4300:4304][2019-10-08T17:43:53]i000: Setting numeric variable ‘VC2013_exists’ to value 0
[4300:4304][2019-10-08T17:43:53]i000: Setting numeric variable ‘VC2015_exists’ to value 1
[4300:4304][2019-10-08T17:43:53]i000: Registry key not found. Key = ‘SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall{ad8a2fa1-06e7-4b0d-927d-6e54b3d31028}’
[4300:4304][2019-10-08T17:43:53]i000: Setting numeric variable ‘VC2005_exists’ to value 0
[4300:4304][2019-10-08T17:43:53]i000: Setting string variable ‘VC2010_build’ to value ‘167812379’
[4300:4304][2019-10-08T17:43:53]i052: Condition ‘VC2005_exists=1 AND VC2005_build>=134278728’ evaluates to false.
[4300:4304][2019-10-08T17:43:53]i052: Condition ‘VC2010_exists=1 AND VC2010_build>=167812379’ evaluates to true.
[4300:4304][2019-10-08T17:43:53]i052: Condition ‘VC2013_exists=1 AND VC2013_version>=v12.0.30501.0’ evaluates to false.
[4300:4304][2019-10-08T17:43:53]i052: Condition ‘VC2015_exists=1 AND VC2015_build>=25810’ evaluates to false.
[4300:4304][2019-10-08T17:43:53]i052: Condition ‘NETFRAMEWORK45 >= 378389’ evaluates to true.
[4300:4304][2019-10-08T17:43:53]i101: Detected package: Redist_VC2005, state: Absent, cached: None
[4300:4304][2019-10-08T17:43:53]i101: Detected package: Redist_VC2010, state: Present, cached: None
[4300:4304][2019-10-08T17:43:53]i101: Detected package: Redist_VC2013, state: Absent, cached: None
[4300:4304][2019-10-08T17:43:53]i101: Detected package: Redist_VC2015, state: Absent, cached: None
[4300:4304][2019-10-08T17:43:53]i101: Detected package: NetFx45Redist, state: Present, cached: None
[4300:4304][2019-10-08T17:43:53]i101: Detected package: rhino.msi, state: Absent, cached: None
[4300:4304][2019-10-08T17:43:53]i101: Detected package: rhiexec.msi, state: Absent, cached: None
[4300:4304][2019-10-08T17:43:53]i101: Detected package: en_lang_pack, state: Absent, cached: None
[4300:4304][2019-10-08T17:43:53]i101: Detected package: fr_lang_pack, state: Absent, cached: None
[4300:4304][2019-10-08T17:43:53]i101: Detected package: it_lang_pack, state: Absent, cached: None
[4300:4304][2019-10-08T17:43:53]i101: Detected package: de_lang_pack, state: Absent, cached: None
[4300:4304][2019-10-08T17:43:53]i101: Detected package: es_lang_pack, state: Absent, cached: None
[4300:4304][2019-10-08T17:43:53]i101: Detected package: ko_lang_pack, state: Absent, cached: None
[4300:4304][2019-10-08T17:43:53]i101: Detected package: ja_lang_pack, state: Absent, cached: None
[4300:4304][2019-10-08T17:43:53]i101: Detected package: tw_lang_pack, state: Absent, cached: None
[4300:4304][2019-10-08T17:43:53]i101: Detected package: cn_lang_pack, state: Absent, cached: None
[4300:4304][2019-10-08T17:43:53]i101: Detected package: pl_lang_pack, state: Absent, cached: None
[4300:4304][2019-10-08T17:43:53]i101: Detected package: cs_lang_pack, state: Absent, cached: None
[4300:4304][2019-10-08T17:43:53]i101: Detected package: pt_lang_pack, state: Absent, cached: None
[4300:4304][2019-10-08T17:43:53]i101: Detected package: ru_lang_pack, state: Absent, cached: None
[4300:4320][2019-10-08T17:43:53]i000: windowsUpdateRequired: ver_NT64 = ‘10.0.0.0’
[4300:4320][2019-10-08T17:43:53]i000: Showing UI from C:\Users\puzzl\AppData\Local\Temp{FA58093C-A996-4D5A-9A6B-78749523E65F}.ba\cn\install.htm
[4300:4304][2019-10-08T17:43:53]i199: Detect complete, result: 0x0
[4300:4320][2019-10-08T17:43:56]i000: GetSystemDefaultLangID() returned 2052
[4300:4320][2019-10-08T17:43:56]i000: GetUserDefaultLangID() returned 2052
[4300:4320][2019-10-08T17:43:56]i000: GetOsLanguage() returned cn
[4300:4320][2019-10-08T17:43:56]i000: version_NT64 = 10.0.0.0; service_pack =
[4300:4320][2019-10-08T17:43:56]i000: Comparing ver_64 (10.0.0.0) to ver_win_7 (6.1.0.0)
[4300:4320][2019-10-08T17:43:56]i000: ver_64 !< ver_win_7
[4300:4320][2019-10-08T17:43:56]i000: Showing UI from C:\Users\puzzl\AppData\Local\Temp{FA58093C-A996-4D5A-9A6B-78749523E65F}.ba\cn\install_advanced.htm
[4300:4320][2019-10-08T17:43:58]i000: Setting hidden variable ‘LICENSE_KEY’
[4300:4320][2019-10-08T17:43:58]i000: Setting string variable ‘CUSTOMER_NAME’ to value ‘’
[4300:4320][2019-10-08T17:43:58]i000: Setting string variable ‘COMPANY_NAME’ to value ‘’
[4300:4320][2019-10-08T17:43:58]i000: Setting string variable ‘INSTALLDIR’ to value ‘C:\Program Files\Rhino 6’
[4300:4320][2019-10-08T17:43:58]i000: Setting numeric variable ‘SEND_STATISTICS’ to value 1
[4300:4320][2019-10-08T17:43:58]i000: Setting numeric variable ‘ENABLE_AUTOMATIC_UPDATES’ to value 1
[4300:4320][2019-10-08T17:43:58]i000: Setting numeric variable ‘INSTALL_EN’ to value 1
[4300:4320][2019-10-08T17:43:58]i000: Setting numeric variable ‘INSTALL_FR’ to value 0
[4300:4320][2019-10-08T17:43:58]i000: Setting numeric variable ‘INSTALL_IT’ to value 0
[4300:4320][2019-10-08T17:43:58]i000: Setting numeric variable ‘INSTALL_DE’ to value 0
[4300:4320][2019-10-08T17:43:58]i000: Setting numeric variable ‘INSTALL_ES’ to value 0
[4300:4320][2019-10-08T17:43:58]i000: Setting numeric variable ‘INSTALL_KO’ to value 0
[4300:4320][2019-10-08T17:43:58]i000: Setting numeric variable ‘INSTALL_JA’ to value 0
[4300:4320][2019-10-08T17:43:58]i000: Setting numeric variable ‘INSTALL_TW’ to value 0
[4300:4320][2019-10-08T17:43:58]i000: Setting numeric variable ‘INSTALL_CN’ to value 0
[4300:4320][2019-10-08T17:43:58]i000: Setting numeric variable ‘INSTALL_PL’ to value 0
[4300:4320][2019-10-08T17:43:58]i000: Setting numeric variable ‘INSTALL_CS’ to value 0
[4300:4320][2019-10-08T17:43:58]i000: Setting numeric variable ‘INSTALL_PT’ to value 0
[4300:4320][2019-10-08T17:43:58]i000: Setting numeric variable ‘INSTALL_RU’ to value 0
[4300:4320][2019-10-08T17:43:58]i000: GetSystemDefaultLangID() returned 2052
[4300:4320][2019-10-08T17:43:58]i000: GetUserDefaultLangID() returned 2052
[4300:4320][2019-10-08T17:43:58]i000: GetOsLanguage() returned cn
[4300:4320][2019-10-08T17:44:08]i000: Setting hidden variable ‘LICENSE_KEY’
[4300:4320][2019-10-08T17:44:08]i000: Setting string variable ‘CUSTOMER_NAME’ to value ‘’
[4300:4320][2019-10-08T17:44:08]i000: Setting string variable ‘COMPANY_NAME’ to value ‘’
[4300:4320][2019-10-08T17:44:08]i000: Setting string variable ‘INSTALLDIR’ to value ‘C:\Program Files\Rhino 6’
[4300:4320][2019-10-08T17:44:08]i000: Setting numeric variable ‘SEND_STATISTICS’ to value 0
[4300:4320][2019-10-08T17:44:08]i000: Setting numeric variable ‘ENABLE_AUTOMATIC_UPDATES’ to value 0
[4300:4320][2019-10-08T17:44:08]i000: Setting numeric variable ‘INSTALL_EN’ to value 0
[4300:4320][2019-10-08T17:44:08]i000: Setting numeric variable ‘INSTALL_FR’ to value 0
[4300:4320][2019-10-08T17:44:08]i000: Setting numeric variable ‘INSTALL_IT’ to value 0
[4300:4320][2019-10-08T17:44:08]i000: Setting numeric variable ‘INSTALL_DE’ to value 0
[4300:4320][2019-10-08T17:44:08]i000: Setting numeric variable ‘INSTALL_ES’ to value 0
[4300:4320][2019-10-08T17:44:08]i000: Setting numeric variable ‘INSTALL_KO’ to value 0
[4300:4320][2019-10-08T17:44:08]i000: Setting numeric variable ‘INSTALL_JA’ to value 0
[4300:4320][2019-10-08T17:44:08]i000: Setting numeric variable ‘INSTALL_TW’ to value 0
[4300:4320][2019-10-08T17:44:08]i000: Setting numeric variable ‘INSTALL_CN’ to value 1
[4300:4320][2019-10-08T17:44:08]i000: Setting numeric variable ‘INSTALL_PL’ to value 0
[4300:4320][2019-10-08T17:44:08]i000: Setting numeric variable ‘INSTALL_CS’ to value 0
[4300:4320][2019-10-08T17:44:08]i000: Setting numeric variable ‘INSTALL_PT’ to value 0
[4300:4320][2019-10-08T17:44:08]i000: Setting numeric variable ‘INSTALL_RU’ to value 0
[4300:4304][2019-10-08T17:44:08]i200: Plan begin, 20 packages, action: Install
[4300:4304][2019-10-08T17:44:08]w321: Skipping dependency registration on package with no dependency providers: Redist_VC2005
[4300:4304][2019-10-08T17:44:08]i000: Setting string variable ‘WixBundleLog_Redist_VC2005’ to value ‘C:\Users\puzzl\AppData\Local\Temp\Rhino_6_20191008174352_000_Redist_VC2005.log’
[4300:4304][2019-10-08T17:44:08]w321: Skipping dependency registration on package with no dependency providers: Redist_VC2010
[4300:4304][2019-10-08T17:44:08]w321: Skipping dependency registration on package with no dependency providers: Redist_VC2013
[4300:4304][2019-10-08T17:44:08]i000: Setting string variable ‘WixBundleLog_Redist_VC2013’ to value ‘C:\Users\puzzl\AppData\Local\Temp\Rhino_6_20191008174352_001_Redist_VC2013.log’
[4300:4304][2019-10-08T17:44:08]w321: Skipping dependency registration on package with no dependency providers: Redist_VC2015
[4300:4304][2019-10-08T17:44:08]i000: Setting string variable ‘WixBundleLog_Redist_VC2015’ to value ‘C:\Users\puzzl\AppData\Local\Temp\Rhino_6_20191008174352_002_Redist_VC2015.log’
[4300:4304][2019-10-08T17:44:08]w321: Skipping dependency registration on package with no dependency providers: NetFx45Redist
[4300:4304][2019-10-08T17:44:08]i000: Setting string variable ‘WixBundleRollbackLog_rhino.msi’ to value ‘C:\Users\puzzl\AppData\Local\Temp\Rhino_6_20191008174352_003_rhino.msi_rollback.log’
[4300:4304][2019-10-08T17:44:08]i000: Setting string variable ‘WixBundleLog_rhino.msi’ to value ‘C:\Users\puzzl\AppData\Local\Temp\Rhino_6_20191008174352_003_rhino.msi.log’
[4300:4304][2019-10-08T17:44:08]i000: Setting string variable ‘WixBundleRollbackLog_rhiexec.msi’ to value ‘C:\Users\puzzl\AppData\Local\Temp\Rhino_6_20191008174352_004_rhiexec.msi_rollback.log’
[4300:4304][2019-10-08T17:44:08]i000: Setting string variable ‘WixBundleLog_rhiexec.msi’ to value ‘C:\Users\puzzl\AppData\Local\Temp\Rhino_6_20191008174352_004_rhiexec.msi.log’
[4300:4304][2019-10-08T17:44:08]i052: Condition ‘INSTALL_EN=1’ evaluates to false.
[4300:4304][2019-10-08T17:44:08]i052: Condition ‘INSTALL_FR=1’ evaluates to false.
[4300:4304][2019-10-08T17:44:08]i052: Condition ‘INSTALL_IT=1’ evaluates to false.
[4300:4304][2019-10-08T17:44:08]i052: Condition ‘INSTALL_DE=1’ evaluates to false.
[4300:4304][2019-10-08T17:44:08]i052: Condition ‘INSTALL_ES=1’ evaluates to false.
[4300:4304][2019-10-08T17:44:08]i052: Condition ‘INSTALL_KO=1’ evaluates to false.
[4300:4304][2019-10-08T17:44:08]i052: Condition ‘INSTALL_JA=1’ evaluates to false.
[4300:4304][2019-10-08T17:44:08]i052: Condition ‘INSTALL_TW=1’ evaluates to false.
[4300:4304][2019-10-08T17:44:08]i052: Condition ‘INSTALL_CN=1’ evaluates to true.
[4300:4304][2019-10-08T17:44:08]i000: Setting string variable ‘WixBundleRollbackLog_cn_lang_pack’ to value ‘C:\Users\puzzl\AppData\Local\Temp\Rhino_6_20191008174352_005_cn_lang_pack_rollback.log’
[4300:4304][2019-10-08T17:44:08]i000: Setting string variable ‘WixBundleLog_cn_lang_pack’ to value ‘C:\Users\puzzl\AppData\Local\Temp\Rhino_6_20191008174352_005_cn_lang_pack.log’
[4300:4304][2019-10-08T17:44:08]i052: Condition ‘INSTALL_PL=1’ evaluates to false.
[4300:4304][2019-10-08T17:44:08]i052: Condition ‘INSTALL_CS=1’ evaluates to false.
[4300:4304][2019-10-08T17:44:08]i052: Condition ‘INSTALL_PT=1’ evaluates to false.
[4300:4304][2019-10-08T17:44:08]i052: Condition ‘INSTALL_RU=1’ evaluates to false.
[4300:4304][2019-10-08T17:44:08]i201: Planned package: Redist_VC2005, state: Absent, default requested: Present, ba requested: Present, execute: Install, rollback: None, cache: Yes, uncache: Yes, dependency: None
[4300:4304][2019-10-08T17:44:08]i201: Planned package: Redist_VC2010, state: Present, default requested: Present, ba requested: Present, execute: None, rollback: None, cache: No, uncache: No, dependency: None
[4300:4304][2019-10-08T17:44:08]i201: Planned package: Redist_VC2013, state: Absent, default requested: Present, ba requested: Present, execute: Install, rollback: None, cache: Yes, uncache: Yes, dependency: None
[4300:4304][2019-10-08T17:44:08]i201: Planned package: Redist_VC2015, state: Absent, default requested: Present, ba requested: Present, execute: Install, rollback: None, cache: Yes, uncache: Yes, dependency: None
[4300:4304][2019-10-08T17:44:08]i201: Planned package: NetFx45Redist, state: Present, default requested: Present, ba requested: Present, execute: None, rollback: None, cache: No, uncache: No, dependency: None
[4300:4304][2019-10-08T17:44:08]i201: Planned package: rhino.msi, state: Absent, default requested: Present, ba requested: Present, execute: Install, rollback: Uninstall, cache: Yes, uncache: No, dependency: Register
[4300:4304][2019-10-08T17:44:08]i201: Planned package: rhiexec.msi, state: Absent, default requested: Present, ba requested: Present, execute: Install, rollback: Uninstall, cache: Yes, uncache: No, dependency: Register
[4300:4304][2019-10-08T17:44:08]i201: Planned package: en_lang_pack, state: Absent, default requested: Absent, ba requested: Absent, execute: None, rollback: None, cache: No, uncache: No, dependency: None
[4300:4304][2019-10-08T17:44:08]i201: Planned package: fr_lang_pack, state: Absent, default requested: Absent, ba requested: Absent, execute: None, rollback: None, cache: No, uncache: No, dependency: None
[4300:4304][2019-10-08T17:44:08]i201: Planned package: it_lang_pack, state: Absent, default requested: Absent, ba requested: Absent, execute: None, rollback: None, cache: No, uncache: No, dependency: None
[4300:4304][2019-10-08T17:44:08]i201: Planned package: de_lang_pack, state: Absent, default requested: Absent, ba requested: Absent, execute: None, rollback: None, cache: No, uncache: No, dependency: None
[4300:4304][2019-10-08T17:44:08]i201: Planned package: es_lang_pack, state: Absent, default requested: Absent, ba requested: Absent, execute: None, rollback: None, cache: No, uncache: No, dependency: None
[4300:4304][2019-10-08T17:44:08]i201: Planned package: ko_lang_pack, state: Absent, default requested: Absent, ba requested: Absent, execute: None, rollback: None, cache: No, uncache: No, dependency: None
[4300:4304][2019-10-08T17:44:08]i201: Planned package: ja_lang_pack, state: Absent, default requested: Absent, ba requested: Absent, execute: None, rollback: None, cache: No, uncache: No, dependency: None
[4300:4304][2019-10-08T17:44:08]i201: Planned package: tw_lang_pack, state: Absent, default requested: Absent, ba requested: Absent, execute: None, rollback: None, cache: No, uncache: No, dependency: None
[4300:4304][2019-10-08T17:44:08]i201: Planned package: cn_lang_pack, state: Absent, default requested: Present, ba requested: Present, execute: Install, rollback: Uninstall, cache: Yes, uncache: No, dependency: Register
[4300:4304][2019-10-08T17:44:08]i201: Planned package: pl_lang_pack, state: Absent, default requested: Absent, ba requested: Absent, execute: None, rollback: None, cache: No, uncache: No, dependency: None
[4300:4304][2019-10-08T17:44:08]i201: Planned package: cs_lang_pack, state: Absent, default requested: Absent, ba requested: Absent, execute: None, rollback: None, cache: No, uncache: No, dependency: None
[4300:4304][2019-10-08T17:44:08]i201: Planned package: pt_lang_pack, state: Absent, default requested: Absent, ba requested: Absent, execute: None, rollback: None, cache: No, uncache: No, dependency: None
[4300:4304][2019-10-08T17:44:08]i201: Planned package: ru_lang_pack, state: Absent, default requested: Absent, ba requested: Absent, execute: None, rollback: None, cache: No, uncache: No, dependency: None
[4300:4320][2019-10-08T17:44:08]i000: GetSystemDefaultLangID() returned 2052
[4300:4320][2019-10-08T17:44:08]i000: GetUserDefaultLangID() returned 2052
[4300:4320][2019-10-08T17:44:08]i000: GetOsLanguage() returned cn
[4300:4320][2019-10-08T17:44:08]i000: version_NT64 = 10.0.0.0; service_pack =
[4300:4320][2019-10-08T17:44:08]i000: Comparing ver_64 (10.0.0.0) to ver_win_7 (6.1.0.0)
[4300:4320][2019-10-08T17:44:08]i000: ver_64 !< ver_win_7
[4300:4320][2019-10-08T17:44:08]i000: Showing UI from C:\Users\puzzl\AppData\Local\Temp{FA58093C-A996-4D5A-9A6B-78749523E65F}.ba\cn\progress.htm
[4300:4304][2019-10-08T17:44:08]i299: Plan complete, result: 0x0
[4300:4304][2019-10-08T17:44:08]i300: Apply begin
[4300:4304][2019-10-08T17:44:09]i010: Launching elevated engine process.
[4300:4304][2019-10-08T17:44:10]i011: Launched elevated engine process.
[4300:4304][2019-10-08T17:44:10]i012: Connected to elevated engine.
[3FB0:25AC][2019-10-08T17:44:10]i358: Pausing automatic updates.
[3FB0:25AC][2019-10-08T17:44:10]i359: Paused automatic updates.
[3FB0:25AC][2019-10-08T17:44:10]i360: Creating a system restore point.
[3FB0:25AC][2019-10-08T17:44:10]i361: Created a system restore point.
[3FB0:25AC][2019-10-08T17:44:10]i370: Session begin, registration key: SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall{26d7302e-cf62-4121-9299-bbf9499d6fde}, options: 0x7, disable resume: No
[3FB0:25AC][2019-10-08T17:44:10]e000: Error 0x80070003: Failed to create cache directory: C:\ProgramData\Package Cache{26d7302e-cf62-4121-9299-bbf9499d6fde}\
[3FB0:25AC][2019-10-08T17:44:10]e000: Error 0x80070003: Failed to create completed cache path for bundle.
[3FB0:25AC][2019-10-08T17:44:10]e000: Error 0x80070003: Failed to cache bundle from path: C:\Users\puzzl\AppData\Local\Temp{FA58093C-A996-4D5A-9A6B-78749523E65F}.be\Bootstrapper.exe
[3FB0:25AC][2019-10-08T17:44:10]e000: Error 0x80070003: Failed to begin registration session.
[4300:4304][2019-10-08T17:44:10]e000: Error 0x80070003: Failed to begin registration session in per-machine process.
[4300:4304][2019-10-08T17:44:10]e000: Error 0x80070003: Failed to register bundle.
[4300:4304][2019-10-08T17:44:11]i399: Apply complete, result: 0x80070003, restart: None, ba requested restart: No
