按Toggle subD display,没有反应
按Toggle subD display,没有反应,只能显示平滑模式
麻烦你在 Rhino指令行执行一下 SystemInfo 指令,然后把弹出内容保存后发上来卡看
Rhino 7 SR3 2021-2-8 (Rhino 7, 7.3.21039.11201, Git hash:master @ 7bcc02a54515376cb2bd3d05f62d9473ab4bc38c)
License type: Evaluation, build 2021-02-08
License details: Stand-Alone
Expires on: 2021-05-11
Windows 10.0.18363 SR0.0 or greater (Physical RAM: 3.8Gb)
Computer platform: LAPTOP - Plugged in [100% battery remaining]
Non-hybrid graphics configuration.
Primary display and OpenGL: Intel® HD Graphics (Intel) Memory: 2GB, Driver date: 11-26-2012 (M-D-Y). OpenGL Ver: 1.1.0
> Integrated graphics device with 2 adapter port(s)
- Windows Main Display is laptop’s integrated screen or built-in port
Secondary graphics devices.
NVIDIA NVS 3100M (NVidia) Memory: 0MB, Driver date: 6-29-2015 (M-D-Y).
> Integrated accelerated graphics device (shares primary device ports)
- This device is not being used
ATTENTION:
No graphics device is being used. Either an error occurred on startup, or certain devices have been disabled.
See below for any possible configuration changes that may help resolve this issue.
  • Any hardware configuration or cabling changes you make will require that you restart Rhino.
OpenGL Settings
Safe mode: Off
Anti-alias mode: None
Mip Map Filtering: Linear
Anisotropic Filtering Mode: High
Vendor Name: Microsoft Corporation
Render version: 0.0
Shading Language: Not supported
Driver Date: 6-29-2015
Driver Version: 9.18.13.4174
Maximum Texture size: 1024 x 1024
Z-Buffer depth: 32 bits
Total Video Memory: n/a
Rhino plugins that do not ship with Rhino
Rhino plugins that ship with Rhino
d:\Program Files\Rhino 7\Plug-ins\Commands.rhp “Commands” 7.3.21039.11201
d:\Program Files\Rhino 7\Plug-ins\rdk.rhp “Renderer Development Kit”
d:\Program Files\Rhino 7\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 7.3.21039.11201
d:\Program Files\Rhino 7\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 7.3.21039.11201
d:\Program Files\Rhino 7\Plug-ins\rdk_ui.rhp “Renderer Development Kit UI”
d:\Program Files\Rhino 7\Plug-ins\NamedSnapshots.rhp “Snapshots”
d:\Program Files\Rhino 7\Plug-ins\RhinoCycles.rhp “RhinoCycles” 7.3.21039.11201
d:\Program Files\Rhino 7\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 7.3.21039.11201
d:\Program Files\Rhino 7\Plug-ins\3dxrhino.rhp “3Dconnexion 3D Mouse”
d:\Program Files\Rhino 7\Plug-ins\Displacement.rhp “Displacement”
看起来你的显卡驱动特别的老旧(集成的Intel和独显 Nvidia都很旧),麻烦你更新至最新的驱动先
  • This device is not being used
之前装旧版本,这个可以切换的
我怀疑是系统兼容性的问题
Rhino 7.3 我在Windows 与 MacOS下测试都很正常,如果你是点击图标出错,请在指令行尝试执行 ToolbarReset 重置工具列试试。
在 Options > Advanced 搜尋 “tab” 找到的 Rhino.Options.ShortcutKeys.Tab 可能和這個問題有關。
把显卡升级一下,可以了
